Introduzione
Before taking apart your device, make sure that you have the proper tools to do so. We used a small screwdriver to remove the screws because they are so tiny. Also, make sure that you are working in an area that is clean and clear of debris so you can see all the parts of your device as you take it apart.
Parti
Nessuna parte richiesta.
Remove screws on the black plate and the side of the device. Remove screws on the black plate and the side of the device.
  • Remove screws on the black plate and the side of the device.
Aggiungi Commento
Remove the small top grey piece from the back plate Detach the back plate from the rest of the device.
  • Remove the small top grey piece from the back plate
  • Detach the back plate from the rest of the device.
Aggiungi Commento
Loosen and remove the screws on the motherboard.
  • Loosen and remove the screws on the motherboard.
Aggiungi Commento
Remove volume rocker from side panel of device.
  • Remove volume rocker from side panel of device.
Aggiungi Commento
Loosen the battery from the motherboard.
  • Loosen the battery from the motherboard.
  • Replace battery with a new one.
Aggiungi Commento
Insert the new battery into the device.
  • Insert the new battery into the device.
Aggiungi Commento
Conclusione
Alyson
Membro da: 18/10/2011
11 Reputazione
1 Guida realizzata
James Madison, Team 1-2, Allen Fall 2011 Membro di James Madison, Team 1-2, Allen Fall 2011
JMU-ALLEN-F11S1G2
3 Membri
1 Guida realizzata
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,746
