Introduzione
Installing a new motherboard involves removing the other components. Once this is done, removing the motherboard involves unscrewing the board from the housing and disconnecting various cables and wires.
Cosa ti serve
Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
Holding the memory module in place, unscrew the three 0.9mm screws with a Phillips #00 screwdriver.
Unscrew the 2.5mm screw on the top portion of the audio module with a Phillips #00 screwdriver.
Use tweezers to unplug the speaker wire from the motherboard by pulling the plug (not the wires) down towards the speaker.
Remove the tape holding speaker wire by peeling it away.
Unplug the ribbon cable found near the bottom of the motherboard by pulling it towards the bottom of the device.
