Introduzione
Use this guide to remove or replace the front panel of the Sony CFD-8 and view the inside of the radio. This process can be hard without a long screwdriver.
Parti
Nessuna parte richiesta.
Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps. Be sure to unplug the boombox from the wall before attempting to open it for repair. Be sure to unplug the boombox from the wall before attempting to open it for repair.
  • Remove the battery cover on the back of the boombox by applying downward pressure to the two clamps.
    • Be sure to unplug the boombox from the wall before attempting to open it for repair.
Aggiungi Commento
Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries. The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
  • Push against the positive end of each battery. Once it is loose, lift the battery out. Repeat for all six batteries.
    • The top row of batteries have the positive side pointing right. The bottom row of batteries have the positive side pointing left.
Aggiungi Commento
Hold the boombox handle at an angle to access the screws behind the CD player. Use a  Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws. Use a  Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
  • Hold the boombox handle at an angle to access the screws behind the CD player.
  • Use a Phillips #1 screwdriver to unscrew the top two 14 mm screws. You may need a flashlight to see the screws.
Aggiungi Commento
Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images. All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
  • Remove four 14 mm screws using a Phillips #1 screwdriver. Two of these screws are at the bottom of the boombox and the other two are on either side of the boombox as highlighted in the related images.
  • All four screws have black arrows (not visible in the photo) indicating their location on the boombox.
Aggiungi Commento
Gently separate the front panel from the back panel. Remove the two connections holding the front panel to boombox. One connection is located on the upper left hand side of the main circuit board.
  • Gently separate the front panel from the back panel.
  • Remove the two connections holding the front panel to boombox.
    • One connection is located on the upper left hand side of the main circuit board.
    • The other is a large white strip slightly to the right of the cassette player.
    • Do not touch the cylindrical parts on the circuit board. These are capacitors and may deliver a shock!
  • Remove the front panel.
Aggiungi Commento
Conclusione
Andrew Kleve
Membro da: 12/10/2014
208 Reputazione
2 Guide realizzate
Cal Poly, Team 10-38, Amido Fall 2014 Membro di Cal Poly, Team 10-38, Amido Fall 2014
CPSU-AMIDO-F14S10G38
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 32
Tutti i Tempi: 948
