Salta al contenuto principale
Sony CDX-GT540UI Fuse Replacement
  1. Sony CDX-GT540UI Fuse Replacement, Wiring Harness: passo 1, immagine 1 di 1
    • Locate the clip on the wiring harness.
  2. Sony CDX-GT540UI Fuse Replacement: passo 2, immagine 1 di 2 Sony CDX-GT540UI Fuse Replacement: passo 2, immagine 2 di 2
    • Press down on the clip like you would an Ethernet cable.
    • Rock harness side to side, pulling gently towards you until harness detaches.
  3. Sony CDX-GT540UI Fuse Replacement, Fuse: passo 3, immagine 1 di 1
    • Once you have removed the wiring harness.
    • Locate the fuse.
  4. Sony CDX-GT540UI Fuse Replacement: passo 4, immagine 1 di 1
    • Using your index finger and thumb on either side of the fuse.
  5. Sony CDX-GT540UI Fuse Replacement: passo 5, immagine 1 di 1
    • Rock back and forth gently pulling towards yourself until the fuse is removed.
Conclusione
USF Tampa, Team 10-2, Brown Fall 2014 Membro di USF Tampa, Team 10-2, Brown Fall 2014
USFT-BROWN-F14S10G2
3 Membri
7 Guide realizzate
Un commento
I would like to sincerely thank the person or persons that took the time ,energy and effort to put forth this information in an easily accessible way. BASICALLY YOU ARE COOL !!
germanspeedster - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 48
Tutti i Tempi: 9,260
