Introduzione
Whether it's due to dust, wear, or physical damage, the main button circuit board may need to be replaced at some point. This guide focuses on how to install a new main button circuit board to get your Sony Bloggie 3D Player running like new.
Cosa ti serve
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Detach the board from the ZIF connector using a pair of tweezers or by hand.
Flip the circuit board over and remove the connector on the backside. Now you can safely remove the circuit board.
