Introduzione
Every battery runs out of power eventually after many uses. This guide will show you how to easily replace the battery on your Sonly Bloggie 3D.
Cosa ti serve
Remove the two 2.5mm Phillips #00 screws using the Philips #00 screwdriver.
Quasi finito!
Conclusione
Un commento
You forgot to mention the need to flip the screen up (a screw holds it down) in order to get to a screw holding the back cover. Other than that, thank you for the info.
