Introduzione
The USB port allows you to connect other devices for charging. The replacement of the USB port requires soldering and if not done properly can damage the device. Guides for how to solder and desolder can be found on iFixit's website. How To Solder and Desolder Connections
Turn off the device by pressing on the clear power button behind the device.
  • Turn off the device by pressing on the clear power button behind the device.
  • To make sure that it is off, make sure the button is not flashing green.
Aggiungi Commento
Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
  • Using the Phillips #1 screwdriver, remove the 2mm screw located on the bottom of the device, near the hinge.
Aggiungi Commento
Using the plastic opening tools, gently pry open the side of the large panel. Keeping the tool in, slowly slide the tool along the side of the panel. Keeping the tool in, slowly slide the tool along the side of the panel.
  • Using the plastic opening tools, gently pry open the side of the large panel.
  • Keeping the tool in, slowly slide the tool along the side of the panel.
Aggiungi Commento
Rotate the device 180 degrees. Make sure the opening on other side of the device does not snap closed.
  • Rotate the device 180 degrees.
  • Make sure the opening on other side of the device does not snap closed.
  • Gently slide the plastic opening tool along the side of the panel.
Aggiungi Commento
Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel. Using both hands, slowly pull apart the back panel from the rest of the device.
  • Do not fully pull apart the back panel from the device. Doing so can rip the two red and blue wires attached to the panel.
  • Using both hands, slowly pull apart the back panel from the rest of the device.
  • Gently flip the back panel open so the circuit board faces up and the two panels are side by side.
Aggiungi Commento
Softly pinch the red and blue wires  close to the white connector. To pull the wires out, wiggle them back and forth until the connector is fully out.
  • Softly pinch the red and blue wires close to the white connector.
  • To pull the wires out, wiggle them back and forth until the connector is fully out.
Aggiungi Commento
Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
  • Unscrew the three 2mm screws holding the circuit board down using a Phillips #1 screwdriver.
Aggiungi Commento
Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
  • Make sure the white USB port cover on the side of the device is pulled out or you won't be able to lift the circuit board.
  • Gently lift the circuit board out of the device using tweezers.
Aggiungi Commento
Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attempting.
  • Soldering can melt key components and cause harm to both the user and the device. Read soldering guide before attempting.
  • Remove solder from both spots on outside of the USB port.
  • Remove solder from base of the USB port.
Aggiungi Commento
Conclusione
Anthony Ramos
Membro da: 20/10/2013
102 Reputazione
1 Guida realizzata
Cal Poly, Team 4-28, Amido Fall 2013 Membro di Cal Poly, Team 4-28, Amido Fall 2013
CPSU-AMIDO-F13S4G28
4 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 508
