Introduzione
Replace the main power board that connects all the components of the lantern.
Flip the lantern upside down. Remove the four Phillips screws from the base.
  • Flip the lantern upside down.
  • Remove the four Phillips screws from the base.
  • Remove the base.
  • Carefully set screws and base plate aside for reassembly.
Aggiungi Commento
Slide the black rubber sleeve off of the outside of the body of the lantern away from the LED globe.
  • Slide the black rubber sleeve off of the outside of the body of the lantern away from the LED globe.
Aggiungi Commento
Remove 4 Phillips head screws from the front of the lantern body below the power button.
  • Remove 4 Phillips head screws from the front of the lantern body below the power button.
  • Set aside screws for reassembly.
Aggiungi Commento
To disassemble the main body, grip the lantern so that the front half of the body with the power button on it is in your right hand and the back half with the hand crank is in your left. Pinch the front half of the body on both sides with your thumb and index finger just below the first extruding rim of the front plate while simultaneously pulling the back half away. This may take some effort to do. Be careful to not pull the halves of the body away from each other too hard because the internal wires connecting internal components may break.
  • To disassemble the main body, grip the lantern so that the front half of the body with the power button on it is in your right hand and the back half with the hand crank is in your left.
  • Pinch the front half of the body on both sides with your thumb and index finger just below the first extruding rim of the front plate while simultaneously pulling the back half away. This may take some effort to do.
  • Be careful to not pull the halves of the body away from each other too hard because the internal wires connecting internal components may break.
  • Take note to remove and set aside black screw mounts located in between the halves at the bottom of the lantern.
  • When putting the front and back plates together during reassembly, make sure to slide the extruding screws from the base of the globe through the corresponding grooves cut into the top of the front and back plates of the main body.
Aggiungi Commento
The main power board is located directly behind the power button, screwed into the front plate. Disconnect all the wires from the main power board by removing the white clips from their corresponding sockets mounted on the board.
  • The main power board is located directly behind the power button, screwed into the front plate.
  • Disconnect all the wires from the main power board by removing the white clips from their corresponding sockets mounted on the board.
  • For reference to replace wires, see labeled picture of main board.
    • LED.
    • DC-in board.
    • Battery.
    • Crank.
  • With the Philips #0 screwdriver, unscrew the four screws mounting the board to the front plate. Remove the board from the front plate. Set aside screws for reassembly.
Aggiungi Commento
Place the new main board so that the screw holes on the front plate line up with the holes on the board.
  • Place the new main board so that the screw holes on the front plate line up with the holes on the board.
  • Make sure the main power button, located behind the main board, is also lined up so that it touches the button on the new main board.
  • Replace screws that were set aside in the previous step.
Aggiungi Commento
Replace all the wires from components into the new main board. Trace the wire from each component and insert where specified on the diagram.
  • Replace all the wires from components into the new main board. Trace the wire from each component and insert where specified on the diagram.
  • Make sure grooves on the clip holding the wires together for each component align with the pins in the socket on the main board before inserting.
Aggiungi Commento
Conclusione
Nicholas Greer
Membro da: 03/10/2012
8 Reputazione
4 Guide realizzate
Cal Poly, Team 18-38, Regan Fall 2012 Membro di Cal Poly, Team 18-38, Regan Fall 2012
CPSU-REGAN-F12S18G38
4 Membri
4 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 1
Tutti i Tempi: 246
