Salta al contenuto principale
Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard
Cosa ti serve
  1. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: passo 1, immagine 1 di 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: passo 1, immagine 2 di 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Case: passo 1, immagine 3 di 3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: passo 2, immagine 1 di 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: passo 2, immagine 2 di 2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, LED Light conducting plastic pieces: passo 3, immagine 1 di 1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: passo 4, immagine 1 di 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: passo 4, immagine 2 di 3 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: passo 4, immagine 3 di 3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  5. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: passo 5, immagine 1 di 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Hard Drive: passo 5, immagine 2 di 2
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  6. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: passo 6, immagine 1 di 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: passo 6, immagine 2 di 2
    • Remove the 4 rubber piece from the plastic frame at each corner.
  7. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: passo 7, immagine 1 di 1
    • Remove the rubber piece from the SATA/USB bridge logic board.
  8. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: passo 8, immagine 1 di 2 Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard, SATA/USB Bridge Motherboard: passo 8, immagine 2 di 2
    • Remove both screws holding the retaining plate and the hard drive.
    • Slide the retaining plate in order to disconnect the SATA connector.
  9. Disassembling Western Digital Essentials HD SATA/USB Bridge Motherboard: passo 9, immagine 1 di 1
    • Remove both screws holding the retaining plate with the logic board.
Conclusione
Gaetan
Membro da: 12/26/12
9.574 Reputazione
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 18
Tutti i Tempi: 2,011
