Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
Aggiungi Commento
While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill. While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill. While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
  • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
Aggiungi Commento
Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill. Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill. Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
  • Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
Aggiungi Commento
Hold drill upright with one hand and slide the gauge backwards to remove it with the other.
  • Hold drill upright with one hand and slide the gauge backwards to remove it with the other.
Aggiungi Commento
The chuck sleeve is held on by a 20mm Phillips #2 screw in the center.This screw is reverse threaded. Insert a Phillips #2 screwdriver and rotate it clockwise to loosen and remove it. The chuck sleeve is held on by a 20mm Phillips #2 screw in the center.This screw is reverse threaded. Insert a Phillips #2 screwdriver and rotate it clockwise to loosen and remove it. The chuck sleeve is held on by a 20mm Phillips #2 screw in the center.This screw is reverse threaded. Insert a Phillips #2 screwdriver and rotate it clockwise to loosen and remove it.
  • The chuck sleeve is held on by a 20mm Phillips #2 screw in the center.This screw is reverse threaded. Insert a Phillips #2 screwdriver and rotate it clockwise to loosen and remove it.
Aggiungi Commento
The threaded hole the screw was in is in the shape of a 6-point star. Insert a T40 Torx Key and rotate it clockwise to loosen and remove the chuck sleeve. The threaded hole the screw was in is in the shape of a 6-point star. Insert a T40 Torx Key and rotate it clockwise to loosen and remove the chuck sleeve.
  • The threaded hole the screw was in is in the shape of a 6-point star. Insert a T40 Torx Key and rotate it clockwise to loosen and remove the chuck sleeve.
Aggiungi Commento
Set the adjustable clutch to the "1" setting before beginning. This will make it easier to remove. The adjustable clutch is held on by 2 20mm T10 Torx screws. Insert a T10 Torx screwdriver and rotate it counterclockwise to loosen and remove each screw.
  • Set the adjustable clutch to the "1" setting before beginning. This will make it easier to remove.
  • The adjustable clutch is held on by 2 20mm T10 Torx screws. Insert a T10 Torx screwdriver and rotate it counterclockwise to loosen and remove each screw.
Aggiungi Commento
Firmly grip the outside of the adjustable clutch and pull it off. There is a metal washer behind the adjustable clutch that holds in 12 small ball bearings. Hold the drill so it is pointing up slightly so the washer and bearings do not fall out.
  • Firmly grip the outside of the adjustable clutch and pull it off.
  • There is a metal washer behind the adjustable clutch that holds in 12 small ball bearings. Hold the drill so it is pointing up slightly so the washer and bearings do not fall out.
Aggiungi Commento
Locate 4 screws on front of the drill. Remove using  Torx T10 Remove front casing piece.
  • Locate 4 screws on front of the drill. Remove using Torx T10
  • Remove front casing piece.
Aggiungi Commento
Locate 4 screws on back of the drill.Remove using  Torx T10. Remove back casing piece.
  • Locate 4 screws on back of the drill.Remove using Torx T10.
  • Remove back casing piece.
Aggiungi Commento
Locate 4 screws on side of the drill. Remove using  Torx T10 Locate 4 screws on side of the drill. Remove using  Torx T10
  • Locate 4 screws on side of the drill. Remove using Torx T10
Aggiungi Commento
After all screws have been removed both side casings can be taken apart.
  • After all screws have been removed both side casings can be taken apart.
Aggiungi Commento
Disconnect all wiring on top of trigger coming from motor and board. Disconnect all wiring on top of trigger coming from motor and board.
  • Disconnect all wiring on top of trigger coming from motor and board.
Aggiungi Commento
Reconnect all wiring to your new trigger
  • Reconnect all wiring to your new trigger
Aggiungi Commento
Conclusione
Daniel
Membro da: 22/09/2014
101 Reputazione
1 Guida realizzata
USF Tampa, Team 2-3, Blackwell Fall 2014 Membro di USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 5
Tutti i Tempi: 319
