Introduzione
If you device handle is detoriorated and you need to remove and/or replace it these are the steps you should follow.
Strumenti
Nessun attrezzo richiesto.
Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
  • Grip the drill. Locate the red locking switch on the back of the battery. Hold the switch down.
Aggiungi Commento
While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill. While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill. While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
  • While holding down the red locking switch, slide the battery towards the back of the drill until the battery is fully removed from the drill.
Aggiungi Commento
Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill. Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill. Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
  • Grip cordless drill firmly with left hand. Grip the cordless drill handle firmly with the right hand. Rotate the handle counterclockwise in order to remove the handle from the drill.
Aggiungi Commento
Conclusione
Sean
Membro da: 23/09/2014
255 Reputazione
2 Guide realizzate
USF Tampa, Team 2-3, Blackwell Fall 2014 Membro di USF Tampa, Team 2-3, Blackwell Fall 2014
USFT-BLACKWELL-F14S2G3
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 165
