Introduzione
If you need to replace your power supply or trigger mechanism, you will have to open up the trigger housing.
Strumenti
Parti
Nessuna parte richiesta.
Use the socket wrench to remove the 0.5" length screw from the bottom of the handle. Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
  • Use the socket wrench to remove the 0.5" length screw from the bottom of the handle.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Separate the cord from the handle. Separate the cord from the handle. Separate the cord from the handle.
  • Separate the cord from the handle.
Aggiungi Commento
Conclusione
Matt
Membro da: 10/10/2010
365 Reputazione
7 Guide realizzate
Cal Poly, Team 5-17, Maness Fall 2010 Membro di Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,066
