Introduzione
Has your motor stopped running? Switch it out.
Parti
Nessuna parte richiesta.
On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
  • On the front of the drill, remove the three 2" flathead screws connecting the front housing to the rear housing.
Aggiungi Commento
Pull the front housing apart from the rear. The motor and gears might fall out when you are pulling it apart.
  • Pull the front housing apart from the rear.
  • The motor and gears might fall out when you are pulling it apart.
Aggiungi Commento
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Remove the gear that is threaded onto the divider. Remove the gear that is threaded onto the divider.
  • Remove the gear that is threaded onto the divider.
Aggiungi Commento
Remove the divider from the rear housing. The motor may come out along with the divider.
  • Remove the divider from the rear housing.
  • The motor may come out along with the divider.
Aggiungi Commento
Pull out the motor. Pull out the motor.
  • Pull out the motor.
Aggiungi Commento
For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it. Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed. Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
  • For reassembly, remove the orange cap on top using your flathead screwdriver. A bushing should come out with it.
  • Depress the bushing on bottom using the tweezers. To reach the bushing you will have to put the tweezers through the "Skil" lettering. Insert the motor as it is depressed.
  • Using the tweezers, place the other bushing back in through the hole in the top. Screw the orange cap back on.
Aggiungi Commento
Conclusione
To continue reassembly, simply follow the guide backwards starting at step 2.
Matt
Membro da: 10/10/2010
365 Reputazione
7 Guide realizzate
Cal Poly, Team 5-17, Maness Fall 2010 Membro di Cal Poly, Team 5-17, Maness Fall 2010
CPSU-MANESS-F10S5G17
3 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 3
Tutti i Tempi: 373
