Salta al contenuto principale
Skateboard Wheel Replacement
Cosa ti serve
  1. Skateboard Wheel Replacement, The skate board fix up: passo 1, immagine 1 di 1
    • With a 13mm wrench, remove the axle nut located in the center of the wheel.
    • Set the axle nut aside, and remove the wheel.
  2. Skateboard Wheel Replacement, Remove the Bearings: passo 2, immagine 1 di 1
    • Position the wheel at the end of the axle.
    • To remove the bearings, gently pry the wheel at a downward angle.
    • Perform this prying process on both sides of the wheel.
    • A bearing spacer should fall out once the bearings are removed.
  3. Skateboard Wheel Replacement: passo 3, immagine 1 di 1
    • Position the new wheel on a flat surface.
    • Press the bearing into the hole of the new wheel.
    • Press firmly until the bearing snaps into place. The bearing's outside edges should be flush with the inside bottom edge of the wheel.
  4. Skateboard Wheel Replacement: passo 4, immagine 1 di 1
    • Flip the wheel over.
    • Insert the bearing spacer into the back the wheel.
  5. Skateboard Wheel Replacement: passo 5, immagine 1 di 1
    • Repeat the method from Step 3 to insert a bearing into the backside of the wheel.
    • With the bearings in place, the wheel can be placed on the axle.
  6. Skateboard Wheel Replacement: passo 6, immagine 1 di 1
    • Slide one washer onto the axle.
  7. Skateboard Wheel Replacement: passo 7, immagine 1 di 1
    • Slide the wheel onto the axle.
    • The axle should go through both bearings and the bearing spacer.
  8. Skateboard Wheel Replacement: passo 8, immagine 1 di 1
    • Slide the second washer onto the axle on the outside of the wheel.
  9. Skateboard Wheel Replacement: passo 9, immagine 1 di 1
    • Tighten the axle nut firmly.
    • Do not over tighten. The wheel should spin freely.
    • Repeat steps 1-9 for the remaining wheels.
Conclusione
Once your wheels are installed, you can ride your skateboard. If you feel your wheels hitting the bottom of your deck when you are turning, you may want to refer to the Wheel Bite Prevention guide.
Altre 9 persone hanno completato questa guida.
Jared Stine
Membro da: 10/05/12
800 Reputazione
3 Guide realizzate
Cal Poly, Team 6-32, Regan Fall 2012 Membro di Cal Poly, Team 6-32, Regan Fall 2012
CPSU-REGAN-F12S6G32
5 Membri
6 Guide realizzate
3 Commenti
Very helpful - just got a skateboard for my son and used this guide to adjust two wheels.
emvxl - Replica
thanks- i needed to upgrade my enjoi wheels to ricta clouds. thanks
Kenzie Peck - Replica
Great and awesome post. It is very helpful. This blog shows the importance of blog commenting. Thanks https://skatingkits.com/best-skateboard-...
Kelly Brien - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 49
Tutti i Tempi: 78,203
