Introduzione
Replace your LCD display only as a last option. Since the LCD display uses a flexible flat cable(FFC), improperly inserting the cable may cause damage to your device.
Parti
Nessuna parte richiesta.
From the back of the device, slide the back panel downwards to unlock the panel.
  • From the back of the device, slide the back panel downwards to unlock the panel.
  • Lift the panel up, exposing the battery.
Aggiungi Commento
Pinch the battery from both sides and lift the battery to remove it. Pinch the battery from both sides and lift the battery to remove it.
  • Pinch the battery from both sides and lift the battery to remove it.
Aggiungi Commento
Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
  • Unscrew the four 6.68mm (1.43mm diameter) Philips #00 screws.
    • If needed, remove the sticker to see the screws
Aggiungi Commento
Start by using a plastic opening tool to loosen the front cover from the sides. Work your way to the bottom of the cover then the top.
  • Start by using a plastic opening tool to loosen the front cover from the sides.
  • Work your way to the bottom of the cover then the top.
  • Carefully pry the front cover off.
Aggiungi Commento
Gently lift the latch on the the ribbon cable connector inward (towards the motherboard).
  • Gently lift the latch on the the ribbon cable connector inward (towards the motherboard).
Aggiungi Commento
Carefully grip the screen and pull it away from the ribbon connector located on the motherboard. Carefully grip the screen and pull it away from the ribbon connector located on the motherboard.
  • Carefully grip the screen and pull it away from the ribbon connector located on the motherboard.
Aggiungi Commento
LCD display (left).
  • LCD display (left).
Aggiungi Commento
Conclusione
Benjamin Her
Membro da: 21/01/2015
552 Reputazione
5 Guide realizzate
USF Tampa, Team 6-6, Brown Winter 2015 Membro di USF Tampa, Team 6-6, Brown Winter 2015
USFT-BROWN-W15S6G6
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 158
