Introduzione
The old volume button is removed by pushing the pushing the volume button upwards and popping it out of the device's case. The new volume button is installed by simply snapping it into volume button slot of the case..
Parti
Nessuna parte richiesta.
Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal. Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
Aggiungi Commento
Use a Philip's head screw driver to remove the screws from the case. Place the screws in a small container to avoid losing them.
  • Use a Philip's head screw driver to remove the screws from the case.
  • Place the screws in a small container to avoid losing them.
Aggiungi Commento
Remove the front cover. First, insert a small pry bar where the black front cover and white back cover meet. Begin prying the black plastic up, slowing moving around to the bottom and other side.
  • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
  • Excellent! Now you have removed the front cover!
Aggiungi Commento
While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
Aggiungi Commento
Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover. Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
Aggiungi Commento
Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
  • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
Aggiungi Commento
Locate the volume button on the side of the device.  The volume button is indicated with an orange rectangle in the photograph.
  • Locate the volume button on the side of the device. The volume button is indicated with an orange rectangle in the photograph.
Aggiungi Commento
Turn the device so that you are looking at the other side of the volume button (from "inside" the device).
  • Turn the device so that you are looking at the other side of the volume button (from "inside" the device).
Aggiungi Commento
Push on the volume button with both of your thumbs.  Wiggle the volume button back and forth as you push upwards.
  • Push on the volume button with both of your thumbs. Wiggle the volume button back and forth as you push upwards.
  • The volume button will pop out.
Aggiungi Commento
Remove the volume button from the device.
  • Remove the volume button from the device.
Aggiungi Commento
Slide the new volume button into the slot for the volume button.
  • Slide the new volume button into the slot for the volume button.
  • Make sure that the volume button is oriented correctly. An easy way to check this is to hold the volume button in place and look at the side of the device.
Aggiungi Commento
Push down on the volume button to snap it back into the case.
  • Push down on the volume button to snap it back into the case.
Aggiungi Commento
Conclusione
Clemson, Team 2-1, Benson Spring 2012 Membro di Clemson, Team 2-1, Benson Spring 2012
CLEM-BENSON-S12S2G1
3 Membri
6 Guide realizzate
Because of the difference between two people in the morning but I'm going&@6899!12;;....,
Rich Ridout - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 1,227
