Introduzione
Taking out the thumbwheel.
Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
  • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
  • Gently pry open button and remove button.
  • Do this for each of the 3 buttons remaining.
Aggiungi Commento
The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off. The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
Aggiungi Commento
Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  • Use the Phillips head screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
  • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
  • Use the Torx 6 screwdriver to remove these 2 screws.
  • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
Aggiungi Commento
After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
  • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
  • You can use your hands to simply pull apart the top casing from the bottom casing.
Aggiungi Commento
Remove 2 screws using the Torx 6 screwdriver.
  • Remove 2 screws using the Torx 6 screwdriver.
Aggiungi Commento
The thumbwheel and casing will be loose, gently remove it.
  • The thumbwheel and casing will be loose, gently remove it.
Aggiungi Commento
Linea Traguardo
michael albaum
Membro da: 20/01/2010
45 Reputazione
11 Guide realizzate
Cal Poly, Team 3-19, Maness Winter 2010 Membro di Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Membri
11 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,037
