Salta al contenuto principale
Sidekick II LCD Screen Replacement
Cosa ti serve
  1. Sidekick II LCD Screen Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II LCD Screen Replacement: passo 2, immagine 1 di 2 Sidekick II LCD Screen Replacement: passo 2, immagine 2 di 2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II LCD Screen Replacement: passo 3, immagine 1 di 1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II LCD Screen Replacement: passo 4, immagine 1 di 1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II LCD Screen Replacement: passo 5, immagine 1 di 1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Sidekick II LCD Screen Replacement, LCD Screen: passo 6, immagine 1 di 2 Sidekick II LCD Screen Replacement, LCD Screen: passo 6, immagine 2 di 2
    • Flip the screen to its up position.
    • Remove screen from keyboard.
  7. Sidekick II LCD Screen Replacement: passo 7, immagine 1 di 1
    • Remove 4 screws from back of screen.
  8. Sidekick II LCD Screen Replacement: passo 8, immagine 1 di 1
    • Separate screen from housing with your fingers.
  9. Sidekick II LCD Screen Replacement: passo 9, immagine 1 di 3 Sidekick II LCD Screen Replacement: passo 9, immagine 2 di 3 Sidekick II LCD Screen Replacement: passo 9, immagine 3 di 3
    • Remove 4 screws
    • Pay attention to the orientation of the screen on the backing because it is difficult to reassemble.
  10. Sidekick II LCD Screen Replacement: passo 10, immagine 1 di 1
    • Remove LCD protective cover with your fingers.
Linea Traguardo
Altre 2 persone hanno completato questa guida.
Cal Poly, Team 3-19, Maness Winter 2010 Membro di Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Membri
11 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 3,650
