Salta al contenuto principale
Sidekick II Battery Replacement
Cosa ti serve
  1. Sidekick II Battery Replacement, Outer Casing: passo 1, immagine 1 di 1
    • Use the plastic opening tool to remove the 4 buttons on each corner of the Sidekick.
    • Gently pry open button and remove button.
    • Do this for each of the 3 buttons remaining.
  2. Sidekick II Battery Replacement: passo 2, immagine 1 di 2 Sidekick II Battery Replacement: passo 2, immagine 2 di 2
    • The bumpers on the top and bottom of the phone can be removed by simply "peeling" them off.
  3. Sidekick II Battery Replacement: passo 3, immagine 1 di 1
    • Use the T6 Torx Screwdriver to remove the 4 screws that are underneath the 4 buttons you removed in step one.
  4. Sidekick II Battery Replacement: passo 4, immagine 1 di 1
    • Flip the screen up halfway (90 degrees), to reveal the 2 screws above the right side of the keyboard.
    • Use the Torx 6 screwdriver to remove these 2 screws.
    • Be careful in handling the phone after removing the screws, because the two main bodies of the phone are no longer attached.
  5. Sidekick II Battery Replacement: passo 5, immagine 1 di 1
    • After removing the 6 screws and both bumpers, the phone will be easy to separate into the two main bodies.
    • You can use your hands to simply pull apart the top casing from the bottom casing.
  6. Sidekick II Battery Replacement, Battery: passo 6, immagine 1 di 1
    • Remove the 5 screws using the Phillips #00 Screwdriver.
  7. Sidekick II Battery Replacement: passo 7, immagine 1 di 1
    • Separate control board from housing using your fingers.
  8. Sidekick II Battery Replacement: passo 8, immagine 1 di 1
    • Lightly pry upward on battery and back plate, and remove.
    • Do not use metal tool to pry. Use your fingers.
Linea Traguardo
Altre 3 persone hanno completato questa guida.
Cal Poly, Team 3-19, Maness Winter 2010 Membro di Cal Poly, Team 3-19, Maness Winter 2010
CPSU-MANESS-W10S3G19
4 Membri
11 Guide realizzate
2 Commenti
I have the battery out. Is their a way to check if it holds a charge? when I plugged charger into sidekick nothing lit up? is it a battery problem or a charge issue? The phone was never damaged. like the rest stop using it so died. figured battery is toast. this was a replacement tutorial. but doesn't show new battery going in to make sure you did correctly. I need the text messages and other data from my phone pretty bad. any help greatly appreciated.
Kyle Wilkins - Replica
Hi, I don’t have any Sidekick-specific advice here, but some for general data recovery from old phones like these. What I’ve done in the past is hunt down another donor phone that is functional, with a working charger, and use it to diagnose the issues on your phone, and make a working model with your motherboard.
Dylan McLaughlin -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 35
Tutti i Tempi: 6,062
