Introduzione
This guide will demonstrate how to remove the two speakers located in the front of the device. Only minimal disassembly is required.
Parti
Nessuna parte richiesta.
Gently position the device so that the buttons and speakers lie face down. Unplug the power cord from the "DC Input."
  • Gently position the device so that the buttons and speakers lie face down.
  • Unplug the power cord from the "DC Input."
Aggiungi Commento
Remove the four 12mm phillips head #2 screws located along the outer edge of the white case. Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together. Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
  • Remove the four 12mm phillips head #2 screws located along the outer edge of the white case.
  • Be careful! There are two small, easily-broken, plastic tabs at the bottom of the device keeping it together.
  • Once you remove the screws, pick the device up so that the grey label on the bottom of the device faces toward you.
  • With your thumbs on either side of the grey label, slowly push with both thumbs until the case pops open.
  • A small gap will open as the two tabs are released.
  • Do not pull the two halves apart yet. They are held together by the speaker wire.
Aggiungi Commento
Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter. Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
  • Grip both sides of the top round part of the case and carefully open it like a clam. The bottom of the two halves are connected by the speaker wire. Do not separate by more than 1 centimeter.
  • Grip either side of the top round part of the case and carefully open the device to reveal all the hidden treasures inside!
  • Lay the device down, so that all the internal components are facing upwards.
Aggiungi Commento
Disconnect the speaker wire from the motherboard by firmly griping the black and red wires close to the connection with two fingers and pulling the connector out. Wiggling the connector back and forth as you pull will make removal easier.
  • Disconnect the speaker wire from the motherboard by firmly griping the black and red wires close to the connection with two fingers and pulling the connector out.
  • Wiggling the connector back and forth as you pull will make removal easier.
Aggiungi Commento
Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case. Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case.
  • Remove the eight 11mm Phillips #1 screws that connect the speakers to the white outer case.
Aggiungi Commento
Conclusione
Melissa Pasa
Membro da: 13/10/2013
701 Reputazione
7 Guide realizzate
Cal Poly, Team 11-33, Amido Fall 2013 Membro di Cal Poly, Team 11-33, Amido Fall 2013
CPSU-AMIDO-F13S11G33
4 Membri
8 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 5
Tutti i Tempi: 431
