Parti
Nessuna parte richiesta.
Place the TV face down on a flat smooth surface as to not scratch the screen. Remove the four 8mm screws attaching the stand to the TV.
  • Place the TV face down on a flat smooth surface as to not scratch the screen.
  • Remove the four 8mm screws attaching the stand to the TV.
Aggiungi Commento
Lift the stand off the television. Lift the stand off the television.
  • Lift the stand off the television.
Aggiungi Commento
Remove the two back panels to display the audio and video inputs.. Remove the two back panels to display the audio and video inputs.. Remove the two back panels to display the audio and video inputs..
  • Remove the two back panels to display the audio and video inputs..
Aggiungi Commento
Remove the eight 6mm Phillips screws around the edge. Remove the two 6mm Phillips near the inputs.
  • Remove the eight 6mm Phillips screws around the edge.
  • Remove the two 6mm Phillips near the inputs.
Aggiungi Commento
Lift and remove the back case of the television.
  • Lift and remove the back case of the television.
Aggiungi Commento
Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires. Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
  • Remove the two speaker cables and the connector from the circuit board by pinching the plastic connectors and firmly pulling up.
  • Pull on the plastic part of the connector, even though it may seem easiest to pull on the wires.
Aggiungi Commento
Remove the green and gray power connector from the side of the buttons panel at the top of the television. Remove the green/gray to orange/gray connector from the center of the circuit board.
  • Remove the green and gray power connector from the side of the buttons panel at the top of the television.
  • Remove the green/gray to orange/gray connector from the center of the circuit board.
Aggiungi Commento
Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case. Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
  • Remove the four 5mm phillips screws attaching the LCD and circuit board to the front case.
Aggiungi Commento
Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
  • Lift the circuit board/LCD block from the case by lifting the near side of the circuit board and sliding it under the button frame.
Aggiungi Commento
Remove the two 6mm Phillips screws. Pull the board toward you, giving you access to the power button. Pull the board toward you, giving you access to the power button.
  • Remove the two 6mm Phillips screws.
  • Pull the board toward you, giving you access to the power button.
Aggiungi Commento
Unscrew the two 4mm Phillips screws. Lift the buttons off the front case.
  • Unscrew the two 4mm Phillips screws.
  • Lift the buttons off the front case.
Aggiungi Commento
Conclusione
Robert Hobson
Membro da: 20/01/2011
1.275 Reputazione
9 Guide realizzate
Cal Poly, Team 1-11, Amido Winter 2011 Membro di Cal Poly, Team 1-11, Amido Winter 2011
CPSU-AMIDO-W11S1G11
4 Membri
9 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 12
Tutti i Tempi: 1,614
