Salta al contenuto principale
Shark Navigator Freestyle SV1106 Battery Pack Replacement
Cosa ti serve
  1. Shark Navigator Freestyle SV1106 Battery Pack Replacement, Battery Pack: passo 1, immagine 1 di 1
    • Turn the device over to reveal the bottom of the motorized brush head.
  2. Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 2, immagine 1 di 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 2, immagine 2 di 2
    • Slide the latch next to the panel upwards into the unlocked position.
  3. Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 3, immagine 1 di 1
    • Slide the panel to the right to reveal the battery.
  4. Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 4, immagine 1 di 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 4, immagine 2 di 2
    • Pull the battery from the vacuum.
  5. Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 5, immagine 1 di 2 Shark Navigator Freestyle SV1106 Battery Pack Replacement: passo 5, immagine 2 di 2
    • Disconnect the battery from the vacuum by pinching the white latch and pulling the two pieces apart.
Conclusione
Altre 3 persone hanno completato questa guida.
Zachary Liu
Membro da: 01/24/18
604 Reputazione
5 Guide realizzate
Cal Poly, Team S1-G5, Livingston Winter 2018 Membro di Cal Poly, Team S1-G5, Livingston Winter 2018
CPSU-LIVINGSTON-W18S1G5
3 Membri
10 Guide realizzate
8 Commenti
How much is the part for the shark
sumi49 - Replica
My Shark SV1106 doesn’t stay on very long. One episode you turn it on it immediately turns off. So what is the issue?
jklab23 - Replica
How much is a battery pack?
ridgeite145 - Replica
Items OrderedPrice1 of: 10.8V 3000mah Battery for Shark XBT1106N SV1110 SV1106N SV1110N SV11O6N SV116N Freestyle Navigator Cordless Stick Vacuum
Sold by: Areotek Direct (seller profile)
Condition: New
James Mayoral -
How much is a new battery pack for replacement
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 65
Tutti i Tempi: 10,754
