Introduzione
This guide will show you how to take apart the fan to remove the Printed Circuit Board.
Parti
Nessuna parte richiesta.
Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
  • Use a Philips #2 screwdriver to unscrew the four 6mm Phillips #0 back screws.
  • Do this by unscrewing from left-to-right then pull the screws out of the back of the fan
Aggiungi Commento
Pull the front and back cover apart.
  • Pull the front and back cover apart.
  • Be careful not to pull the front cover off completely because it holds the wires.
Aggiungi Commento
Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
  • Remove the Phillips (5-mm head) 6-mm screw that holds the circuit board to the outer shell of the fan.
  • Make sure the fan is unplugged while removing the circuit board as you may get shocked.
  • To remove the screws, unscrew in a left-to-right fashion at an angle to make sure that the wires do not get tangled.
Aggiungi Commento
Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
  • Remove the top cover containing the circuit board and the wires by pulling it away from the body of the fan.
Aggiungi Commento
Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you  may damage circuit elements. Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
  • Remove the circuit board from the top cover. Do not touch the other side of the circuit board as you may damage circuit elements.
  • Unscrew the four screws on the top of the circuit board in a left-to-right fashion. After pull screws out of the board.
Aggiungi Commento
Conclusione
Mateo Begue
Membro da: 26/09/2012
78 Reputazione
2 Guide realizzate
Cal Poly, Team 15-46, Forte Fall 2012 Membro di Cal Poly, Team 15-46, Forte Fall 2012
CPSU-FORTE-F12S15G46
5 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 12
Tutti i Tempi: 783
