Introduzione
Separate your phone's front and back cover.
Parti
Nessuna parte richiesta.
Rotate the phone onto its front side so that the LCD screen is facing away from you.
  • Rotate the phone onto its front side so that the LCD screen is facing away from you.
Aggiungi Commento
Remove the battery by pressing down on the battery release button while sliding the battery downwards. Remove the battery by pressing down on the battery release button while sliding the battery downwards. Remove the battery by pressing down on the battery release button while sliding the battery downwards.
  • Remove the battery by pressing down on the battery release button while sliding the battery downwards.
Aggiungi Commento
Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
  • Remove the four small black screws that secure the back phone panel using the Phillips #00 screwdriver.
  • Complete removal of screws may not be necessary.
Aggiungi Commento
Carefully separate the front and back panels by gently prying them apart.  Start at the bottom of the phone (near the AC charger input). Volume control button will be unsecured and may fall out as soon as the panels are separated. Gentle force may be required to separate the panels at the top latch.
  • Carefully separate the front and back panels by gently prying them apart. Start at the bottom of the phone (near the AC charger input).
  • Volume control button will be unsecured and may fall out as soon as the panels are separated.
  • Gentle force may be required to separate the panels at the top latch.
  • There are two wires connecting the front and back panels. Be careful not to rip these wires out when separating the panels.
Aggiungi Commento
Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily. Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
  • Using your nails, tweezers, or any precise grabbing tool, pinch the antenna wire connector (clear plastic plug) and pull gently. It should pop out rather easily.
Aggiungi Commento
Conclusione
DJ Tarazona
Membro da: 13/04/2010
25 Reputazione
3 Guide realizzate
Cal Poly, Team 28-29, Regan Spring 2010 Membro di Cal Poly, Team 28-29, Regan Spring 2010
CPSU-REGAN-S10S28G29
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 1,803
