Introduzione
We all know that the Sega Genesis brought to us many hours of fun, but, as we get older, the reset button gets older too.
Today, let's lend a hand to our nice friend and replace its reset button!
Parti
Nessuna parte richiesta.
Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
Aggiungi Commento
Flip the Sega Genesis upright.
  • Flip the Sega Genesis upright.
Aggiungi Commento
Gently lift the top casing.
  • Gently lift the top casing.
  • Note: the case will be connected to the main board by LED wires.
Aggiungi Commento
Bend out the LED leads into vertical positions.
  • Bend out the LED leads into vertical positions.
Aggiungi Commento
Slide the LED wire apparatus off the lead pins.
  • Slide the LED wire apparatus off the lead pins.
  • Note: observe which color wire corresponds with which length of pin.
Aggiungi Commento
Separate the main board from the outer case.
  • Separate the main board from the outer case.
Aggiungi Commento
Using Philips screwdriver, remove 11 screws securing silver casing.
  • Using Philips screwdriver, remove 11 screws securing silver casing.
Aggiungi Commento
Remove silver case.
  • Remove silver case.
Aggiungi Commento
Locate reset button on motherboard
  • Locate reset button on motherboard
Aggiungi Commento
Place three pieces of 1cm x 1cm masking tape over reset button.
  • Place three pieces of 1cm x 1cm masking tape over reset button.
You could also, if you feel confident in your skills, desolder the old button and replace it with a standard 4-pin pushbutton. Resolder the new one, and it should work.
Tsaku - Replica
Conclusione
To reassemble your device, follow these instructions in reverse order. And the most important, be happy!
calvin
Membro da: 05/10/2010
186 Reputazione
1 Guida realizzata
Cal Poly, Team 3-29, Regan Fall 2010 Membro di Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 16
Ultimi 30 Giorni: 74
Tutti i Tempi: 11,013
