Introduzione
This repair guide wil give a walk through on how to replace the power LED in a Sega Genesis.
Parti
Nessuna parte richiesta.
Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
Aggiungi Commento
Flip the Sega Genesis upright.
  • Flip the Sega Genesis upright.
Aggiungi Commento
Gently lift the top casing.
  • Gently lift the top casing.
  • Note: the case will be connected to the main board by LED wires.
Aggiungi Commento
Bend out the LED leads into vertical positions.
  • Bend out the LED leads into vertical positions.
Aggiungi Commento
Slide the LED wire apparatus off the lead pins.
  • Slide the LED wire apparatus off the lead pins.
  • Note: observe which color wire corresponds with which length of pin.
Aggiungi Commento
Separate the main board from the outer case.
  • Separate the main board from the outer case.
Aggiungi Commento
Remove plastic "Power / On" cover by pushing tabs together.
  • Remove plastic "Power / On" cover by pushing tabs together.
Aggiungi Commento
Pull "Power / On" cover away from the console cover.
  • Pull "Power / On" cover away from the console cover.
Aggiungi Commento
From the outside of the top cover, remove LED.
  • From the outside of the top cover, remove LED.
Aggiungi Commento
Insert new LED (Click here to buy LED.)
Aggiungi Commento
Re-insert "Power / On" cover until it clicks into place.
  • Re-insert "Power / On" cover until it clicks into place.
Aggiungi Commento
Conclusione
Altre 5 persone hanno completato questa guida.
Anthony Porchia
Membro da: 11/10/2010
341 Reputazione
1 Guida realizzata
Cal Poly, Team 3-29, Regan Fall 2010 Membro di Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Membri
5 Guide realizzate
My LED won't turn on when I turn on the machine though when I took it out and touched it on a battery it lit up. Did I put it back in wrong or what?
Brandon - Replica
Long leg on the LED goes to the red wire.
Short leg to the white wire. If that's not the case, you may have burned the LED or the spot doesn't work anymore.
Last attempt would be getting your +V5 from the resistor below as shown in this image.
http://i.imgur.com/TucGEXj.jpg
Thunder....16
PIero Bogani -
The model I am trying to change the led on is the 1601 HD graphics Genesis. The problem I have is there are NO simple easy press tabs to pop off the red ring. What is the correct way to remove the LED on this model? Thank you for your time.
snoopydaturd - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 91
Tutti i Tempi: 10,592
