Salta al contenuto principale
Sega Genesis Motherboard Replacement
Cosa ti serve
  1. Sega Genesis Motherboard Replacement, Outer Case: passo 1, immagine 1 di 1
    • Remove the six screws from the underside of the console with a Phillips #1 screwdriver.
  2. Sega Genesis Motherboard Replacement: passo 2, immagine 1 di 1
    • Flip the Sega Genesis upright.
  3. Sega Genesis Motherboard Replacement: passo 3, immagine 1 di 1
    • Gently lift the top casing.
    • Note: the case will be connected to the main board by LED wires.
  4. Sega Genesis Motherboard Replacement: passo 4, immagine 1 di 1
    • Bend out the LED leads into vertical positions.
  5. Sega Genesis Motherboard Replacement: passo 5, immagine 1 di 1
    • Slide the LED wire apparatus off the lead pins.
    • Note: observe which color wire corresponds with which length of pin.
  6. Sega Genesis Motherboard Replacement: passo 6, immagine 1 di 1
    • Separate the main board from the outer case.
  7. Sega Genesis Motherboard Replacement, Motherboard: passo 7, immagine 1 di 1
    • Remove single black screw from the outside of the bottom cover, using a Philips screwdriver.
  8. Sega Genesis Motherboard Replacement: passo 8, immagine 1 di 1
    • Using a Philips screwdriver, remove 11 screws securing silver casing.
  9. Sega Genesis Motherboard Replacement: passo 9, immagine 1 di 1
    • Remove silver case.
  10. Sega Genesis Motherboard Replacement: passo 10, immagine 1 di 1
    • Remove single golden screw on motherboard using Philips screwdriver.
    • Note: Push headphone jack to the side.
  11. Sega Genesis Motherboard Replacement: passo 11, immagine 1 di 1
    • Remove two black screws on the left and right sides of the cartridge slot.
  12. Sega Genesis Motherboard Replacement: passo 12, immagine 1 di 1
    • Remove motherboard.
  13. Sega Genesis Motherboard Replacement: passo 13, immagine 1 di 1
    • Re-install new motherboard.
Conclusione
Altre 13 persone hanno completato questa guida.
Cal Poly, Team 3-29, Regan Fall 2010 Membro di Cal Poly, Team 3-29, Regan Fall 2010
CPSU-REGAN-F10S3G29
4 Membri
14 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 4
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 207
Tutti i Tempi: 32,976
