Salta al contenuto principale
Sega Game Gear Case Replacement
Cosa ti serve
  1. Sega Game Gear Case Replacement, Battery: passo 1, immagine 1 di 1
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Case Replacement: passo 2, immagine 1 di 1
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Case Replacement, Case: passo 3, immagine 1 di 1
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Case Replacement: passo 4, immagine 1 di 1
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Case Replacement: passo 5, immagine 1 di 2 Sega Game Gear Case Replacement: passo 5, immagine 2 di 2
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Case Replacement: passo 6, immagine 1 di 3 Sega Game Gear Case Replacement: passo 6, immagine 2 di 3 Sega Game Gear Case Replacement: passo 6, immagine 3 di 3
    • Carefully unplug the 2 white-tipped connectors on the top cover.
Conclusione
Altre 9 persone hanno completato questa guida.
Cal Poly, Team 28-33, Regan Spring 2010 Membro di Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Membri
13 Guide realizzate
Un commento
Is this guide made to help replacing the Game Gear shell? Almost doesn't seem like a thorough guide, I'm still seeing screws on the motherboard in the last photo, I assume those get taken out too?
Alex Tomalty - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 23
Ultimi 30 Giorni: 99
Tutti i Tempi: 19,635
