Introduzione
A guide to remove the GD-ROM from the Sega Dreamcast.
Problem with this guide: The photos incorrectly show the power supply has been removed.
Parti
Nessuna parte richiesta.
Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
Aggiungi Commento
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Aggiungi Commento
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
Aggiungi Commento
Detach the orange cable  by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board. Detach the orange cable  by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
  • Detach the orange cable by giving it a gentle pull while wiggling the cable back and forth until it loosens from the logic board.
Aggiungi Commento
Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board. Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
  • Detach the cables by gently pulling the three GD-ROM cables to remove them from the logic board.
Aggiungi Commento
Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket. The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
  • Remove the two black 12mm Philips #02 screws located on the left side of the GD-ROM bracket.
  • The console is rotated 90 degrees counter-clockwise in the first photo. The second photo depicts the normal position.
Aggiungi Commento
When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base. Remove the GD-ROM by gently lifting it from its base.
  • When lifting the GD-ROM, be careful that the top half of the casing does not detached from its base.
  • Remove the GD-ROM by gently lifting it from its base.
Aggiungi Commento
Conclusione
Altre 7 persone hanno completato questa guida.
wkwong
Membro da: 14/11/2009
402 Reputazione
13 Guide realizzate
Cal Poly, Team 5-1, Regan Fall 2009 Membro di Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Membri
23 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 14
Ultimi 30 Giorni: 69
Tutti i Tempi: 14,701
