Introduzione
This guide details how to replace a malfunctioning fan in the Sega Dreamcast.
Be sure to replace the fan with one corresponding to your Model Number. Refer to the Top Cover Disassembly Guide for instructions on where to find your model number.
Parti
Nessuna parte richiesta.
Verify that the console is disconnected from the AC outlet before you begin. Flip the console over on its back.
  • Verify that the console is disconnected from the AC outlet before you begin.
  • Flip the console over on its back.
  • Take note of your model number, in case replacement parts are needed.
Aggiungi Commento
Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console. Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
  • Remove the expansion bay by applying pressure to the small clip on the expansion bay while prying it away from the console.
Aggiungi Commento
Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Locate and remove all four black 12mm Phillips #02 screws from the underside of the console.
  • Note: Remove the expansion bay to locate the fourth screw
Aggiungi Commento
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Internal components can be loose. Be careful that they do not fall out when removing the cover.
  • Turn the console right side up.
  • Remove the top cover by gently lifting the upper portion of the console.
Aggiungi Commento
Remove the white fan header by gently pulling it away from from the controller port.
  • Remove the white fan header by gently pulling it away from from the controller port.
  • The white fan header may already be detached if you have completed the Controller Port Disassembly Guide.
Aggiungi Commento
Remove the two 8.5mm Philips #00 screws from the fan bracket.
  • Remove the two 8.5mm Philips #00 screws from the fan bracket.
Aggiungi Commento
Remove the two 17.5mm Philips #00 screws from the fan bracket. Remove the fan from the bracket.
  • Remove the two 17.5mm Philips #00 screws from the fan bracket.
  • Remove the fan from the bracket.
Aggiungi Commento
Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws. Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
  • Connect the new fan to the fan bracket using two 17.5mm Philips #00 screws.
  • Replace the fan bracket in the Dreamcast using two 8.5mm Philips #00 screws.
Aggiungi Commento
Conclusione
Altre 3 persone hanno completato questa guida.
Thorr686
Membro da: 06/11/2009
360 Reputazione
4 Guide realizzate
Cal Poly, Team 5-1, Regan Fall 2009 Membro di Cal Poly, Team 5-1, Regan Fall 2009
CPSU-REGAN-F09S5G1
5 Membri
23 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 56
Tutti i Tempi: 13,616
