Salta al contenuto principale
Sega CD Plastic Housing Removal
Cosa ti serve
  1. Sega CD Plastic Housing Removal, Sega CD Plastic Housing Removal: passo 1, immagine 1 di 2 Sega CD Plastic Housing Removal, Sega CD Plastic Housing Removal: passo 1, immagine 2 di 2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD Plastic Housing Removal: passo 2, immagine 1 di 1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD Plastic Housing Removal: passo 3, immagine 1 di 1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD Plastic Housing Removal: passo 4, immagine 1 di 1
    • Lift from the left side to remove the top of the case.
  5. Sega CD Plastic Housing Removal: passo 5, immagine 1 di 1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD Plastic Housing Removal: passo 6, immagine 1 di 1
    • Lift the top of the case to remove the cover.
  7. Sega CD Plastic Housing Removal: passo 7, immagine 1 di 1
    • Remove the faceplate by pulling it up, then out.
Conclusione
To reassemble the device, follow these instructions in reverse order.
Cal Poly, Team 5-14, Maness Fall 2010 Membro di Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 4,883
