Salta al contenuto principale
Sega CD Genesis Connector Replacement
Cosa ti serve
  1. Sega CD Genesis Connector Replacement, Sega CD Plastic Housing Removal: passo 1, immagine 1 di 2 Sega CD Genesis Connector Replacement, Sega CD Plastic Housing Removal: passo 1, immagine 2 di 2
    • Using a Phillips head screwdriver remove six screws from the bottom of the console.
    • The six screws are marked.
  2. Sega CD Genesis Connector Replacement: passo 2, immagine 1 di 1
    • Remove the two screws that attach the Genesis' connector to the rest of the console.
    • The two screws are marked in the diagram.
  3. Sega CD Genesis Connector Replacement: passo 3, immagine 1 di 1
    • Slide the lock tab to the left to separate the halves of the console.
  4. Sega CD Genesis Connector Replacement: passo 4, immagine 1 di 1
    • Lift from the left side to remove the top of the case.
  5. Sega CD Genesis Connector Replacement: passo 5, immagine 1 di 1
    • Using the spudger, pry the cover off of the Genesis attachment.
  6. Sega CD Genesis Connector Replacement: passo 6, immagine 1 di 1
    • Lift the top of the case to remove the cover.
  7. Sega CD Genesis Connector Replacement: passo 7, immagine 1 di 1
    • Remove the faceplate by pulling it up, then out.
  8. Sega CD Genesis Connector Replacement, Genesis Connector: passo 8, immagine 1 di 2 Sega CD Genesis Connector Replacement, Genesis Connector: passo 8, immagine 2 di 2
    • Using a #00 Philips screwdriver remove the two screws that attach the Genesis adapter to the console.
    • Disconnect the adapter from the console by carefully pulling the adapter out.
  9. Sega CD Genesis Connector Replacement: passo 9, immagine 1 di 1
    • Remove the four screws from the metal plate as shown using a #00 Philips screwdriver.
    • The four half inch bronze screws are indicated by the yellow marking circles.
  10. Sega CD Genesis Connector Replacement: passo 10, immagine 1 di 2 Sega CD Genesis Connector Replacement: passo 10, immagine 2 di 2
    • Carefully remove the metal cover from the connector by sliding the cover up and out.
  11. Sega CD Genesis Connector Replacement: passo 11, immagine 1 di 2 Sega CD Genesis Connector Replacement: passo 11, immagine 2 di 2
    • Remove the connector from the housing.
Conclusione
Cal Poly, Team 5-14, Maness Fall 2010 Membro di Cal Poly, Team 5-14, Maness Fall 2010
CPSU-MANESS-F10S5G14
4 Membri
12 Guide realizzate
3 Commenti
So, I'm assuming you are doing this to correct a connection problem between the Sega CD and Genesis. Now that it's disassembled are you slightly bending the connections for a better fit, or cleaning the connectors to remove over 20 years of tarnish build up, or replacing all together with a new manufactured unit? By the way, I have my Sega CD and Genesis still to this day. They are in their original box with all the manuals and other pamphlets that they came with. I should see if Sherlock Holmes is still boring as it was when I first played it back in '91. Better yet play Night Trap and think about how controversial this game was at the time and even was pulled from store shelves, because of the controversy surrounding the girls outfits worn in the game.
helliant1 - Replica
Anyone know where I can obtain a new connector slot? I got my unit from a friend and one of the pins are crushed into the back of the the plastic housing. Can not pull the prong out and need a new connector. Can’t seem to find this connector on ebay or anywhere else.
joeybinky - Replica
I also need a new Genesis Connector. Mine is bent and I can't get a clean fit from the console. Where can we purchase replacement parts?
brothermers3 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 27
Tutti i Tempi: 5,869
