Introduzione
Use this guide to remove the power supply unit.
Parti
Nessuna parte richiesta.
Place the monitor face down.
  • Place the monitor face down.
  • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
  • Remove the stand by pulling it out.
Aggiungi Commento
Remove two 11.5mm screws with a  #2 Phillips screwdriver.
  • Remove two 11.5mm screws with a #2 Phillips screwdriver.
  • Remove the plastic bar.
Aggiungi Commento
Using a  #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
Aggiungi Commento
Pry the monitor using the plastic opening tool to release the clips holding the cover on. There are four clips on each side, four on the top, and one on the bottom. You may hear a loud snapping noise when releasing the clips.  Do not be alarmed, it is natural.
  • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
  • Once all the clips have been released, remove the cover by pulling it up.
Aggiungi Commento
Using the  #2 Phillips screwdriver, remove the one 6mm screw. Unplug the indicated cable by pulling on the base.
  • Using the #2 Phillips screwdriver, remove the one 6mm screw.
  • Unplug the indicated cable by pulling on the base.
  • Slide the cover toward the top of the monitor.
  • Remove the cover.
Aggiungi Commento
Using a #2 Phillips screwdriver, remove the two 4.72 mm Phillips screws that hold the power adapter in place.
  • Using a #2 Phillips screwdriver, remove the two 4.72 mm Phillips screws that hold the power adapter in place.
Aggiungi Commento
Unplug the seven connections from the power supply unit by gently pulling on them. Unplug the seven connections from the power supply unit by gently pulling on them. Unplug the seven connections from the power supply unit by gently pulling on them.
  • Unplug the seven connections from the power supply unit by gently pulling on them.
Aggiungi Commento
Using a #2 Phillips screwdriver, remove the screws and the wire that is attached to the ground.
  • Using a #2 Phillips screwdriver, remove the screws and the wire that is attached to the ground.
    • Four 6 mm Phillips screws
    • One 8 mm Phillips screw
Aggiungi Commento
Lift the power supply unit straight up to remove it from the back panel. Lift the power supply unit straight up to remove it from the back panel.
  • Lift the power supply unit straight up to remove it from the back panel.
Aggiungi Commento
Conclusione
Jose Carrillo
Membro da: 26/09/2012
23 Reputazione
1 Guida realizzata
Cal Poly, Team 16-56, Forte Fall 2012 Membro di Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 506
