Place the monitor face down.
  • Place the monitor face down.
  • Remove the four 11.5mm screws with a #2 Phillips screwdriver.
  • Remove the stand by pulling it out.
Aggiungi Commento
Remove two 11.5mm screws with a  #2 Phillips screwdriver.
  • Remove two 11.5mm screws with a #2 Phillips screwdriver.
  • Remove the plastic bar.
Aggiungi Commento
Using a  #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
  • Using a #2 Phillips screwdriver, remove the six 7mm screws at the circled locations.
Aggiungi Commento
Pry the monitor using the plastic opening tool to release the clips holding the cover on. There are four clips on each side, four on the top, and one on the bottom. You may hear a loud snapping noise when releasing the clips.  Do not be alarmed, it is natural.
  • Pry the monitor using the plastic opening tool to release the clips holding the cover on.
    • There are four clips on each side, four on the top, and one on the bottom.
    • You may hear a loud snapping noise when releasing the clips. Do not be alarmed, it is natural.
  • Once all the clips have been released, remove the cover by pulling it up.
Aggiungi Commento
Using the  #2 Phillips screwdriver, remove the one 6mm screw. Unplug the indicated cable by pulling on the base.
  • Using the #2 Phillips screwdriver, remove the one 6mm screw.
  • Unplug the indicated cable by pulling on the base.
  • Slide the cover toward the top of the monitor.
  • Remove the cover.
Aggiungi Commento
Use caution when removing the connectors as they can easily break when removing. Disconnect the two connectors at the top-left of the power board. Disconnect the two connectors at the very bottom of the power board (pink wire).
  • Use caution when removing the connectors as they can easily break when removing.
    • Disconnect the two connectors at the top-left of the power board.
    • Disconnect the two connectors at the very bottom of the power board (pink wire).
    • Disconnect the multi-pin connector at the top of the motherboard.
  • A small flat-blade screwdriver or tweezers can be used to assist in removal of connectors.
Aggiungi Commento
Use a #2 Phillips to unscrew the two 4.5mm screws on each side of the back panel. Carefully side the connectors through their respective openings. Lif the back panel to reveal the LCD back cover.
  • Use a #2 Phillips to unscrew the two 4.5mm screws on each side of the back panel.
  • Carefully side the connectors through their respective openings.
  • Lif the back panel to reveal the LCD back cover.
Aggiungi Commento
Use a #2 Phillips to remove the four  6mm screws on the bezel for each side of the back cover. Remove the bezels from the LCD back cover (the bezels should simply fall off once the screws are removed). Remove the bezels from the LCD back cover (the bezels should simply fall off once the screws are removed).
  • Use a #2 Phillips to remove the four 6mm screws on the bezel for each side of the back cover.
    • Remove the bezels from the LCD back cover (the bezels should simply fall off once the screws are removed).
Aggiungi Commento
Use a #0 Phillips to remove the three 4.5mm screws located on the LCD back cover. Lift the inner panel to remove it. Disconnect the muti-pin connector on the LCD back cover by firmly pulling down on it.
  • Use a #0 Phillips to remove the three 4.5mm screws located on the LCD back cover.
    • Lift the inner panel to remove it.
  • Disconnect the muti-pin connector on the LCD back cover by firmly pulling down on it.
Aggiungi Commento
Use a #0 Phillips to remove the two 6mm screws on each side of the LCD cover. There are tabs holding down the cover. You may have to use a bit of force to pry them open.
  • Use a #0 Phillips to remove the two 6mm screws on each side of the LCD cover.
  • There are tabs holding down the cover. You may have to use a bit of force to pry them open.
    • A small flat-blade screwdriver can be used to pry off LCD cover.
Aggiungi Commento
Lift the LCD back cover to reveal the LCD screen below. Lift the LCD back cover to reveal the LCD screen below. Lift the LCD back cover to reveal the LCD screen below.
  • Lift the LCD back cover to reveal the LCD screen below.
Aggiungi Commento
Conclusione
Alvin Lam
Membro da: 26/09/2012
40 Reputazione
1 Guida realizzata
Cal Poly, Team 16-56, Forte Fall 2012 Membro di Cal Poly, Team 16-56, Forte Fall 2012
CPSU-FORTE-F12S16G56
5 Membri
7 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 308
