Introduzione
Use this guide to replace the function set.
Parti
Nessuna parte richiesta.
Place your thumb on the right side of the camera over the battery door.
  • Place your thumb on the right side of the camera over the battery door.
  • Slide the battery door to the right until the door lifts up.
Aggiungi Commento
Remove and recycle old batteries.
  • Remove and recycle old batteries.
Aggiungi Commento
Unscrew 6 Phillips screws using the #00 Phillips screwdriver. Two screws are on the left side of the camera. Two screws are on the right side of the camera.
  • Unscrew 6 Phillips screws using the #00 Phillips screwdriver.
    • Two screws are on the left side of the camera.
    • Two screws are on the right side of the camera.
    • Two screws are on the bottom of the camera.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Open battery slot on the bottom of the camera by sliding the door to the right. Remove the 4 mm phillips screw on the bottom right using the #00 phillips screwdriver.
  • Open battery slot on the bottom of the camera by sliding the door to the right.
  • Remove the 4 mm phillips screw on the bottom right using the #00 phillips screwdriver.
Aggiungi Commento
Insert spudger in the seam at the bottom of the camera. Gently separate the rear case from the front of the camera. Gently separate the rear case from the front of the camera.
  • Insert spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
Aggiungi Commento
This step is only needed for the case and logic board replacement
  • This step is only needed for the case and logic board replacement
  • Using the #00 phillips screwdriver remove the screw attached to the front casing in the top left corner. Front case should easily separate.
Skip this step for the function set replacement.
Ariana Martinez - Replica
This step is only needed for the case replacement.
  • This step is only needed for the case replacement.
  • Using the #00 phillips screwdriver remove the screw on the inside of the battery door.
  • Slide the battery door off of the hinge.
This step is needed only for the case replacement.
Remove the function set strip by lifting it from the inside of the rear case. The function strip is now free from the camera.
  • Remove the function set strip by lifting it from the inside of the rear case.
  • The function strip is now free from the camera.
Aggiungi Commento
Conclusione
Ariana Martinez
Membro da: 15/04/2010
50 Reputazione
4 Guide realizzate
Cal Poly, Team 24-24, Regan Spring 2010 Membro di Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,406
