Salta al contenuto principale
Sanyo VPC S1275 Case Replacement
Cosa ti serve
  1. Sanyo VPC S1275 Case Replacement, Battery: passo 1, immagine 1 di 1
    • Place your thumb on the right side of the camera over the battery door.
    • Slide the battery door to the right until the door lifts up.
  2. Sanyo VPC S1275 Case Replacement: passo 2, immagine 1 di 1
    • Remove and recycle old batteries.
  3. Sanyo VPC S1275 Case Replacement, Case: passo 3, immagine 1 di 3 Sanyo VPC S1275 Case Replacement, Case: passo 3, immagine 2 di 3 Sanyo VPC S1275 Case Replacement, Case: passo 3, immagine 3 di 3
    • Remove the following six screws using the Phillips #00 screwdriver:
    • Two screws on the left side of the camera.
    • Two screws on the right side of the camera.
    • Two screws on the bottom of the camera.
  4. Sanyo VPC S1275 Case Replacement: passo 4, immagine 1 di 2 Sanyo VPC S1275 Case Replacement: passo 4, immagine 2 di 2
    • Open the battery slot on the bottom of the camera by sliding the door to the right.
    • Remove the single 4 mm screw on the bottom right using the Phillips #00 screwdriver.
  5. Sanyo VPC S1275 Case Replacement: passo 5, immagine 1 di 3 Sanyo VPC S1275 Case Replacement: passo 5, immagine 2 di 3 Sanyo VPC S1275 Case Replacement: passo 5, immagine 3 di 3
    • Insert a spudger in the seam at the bottom of the camera.
    • Gently separate the rear case from the front of the camera.
  6. Sanyo VPC S1275 Case Replacement: passo 6, immagine 1 di 1
    • This step is only needed for the case and logic board replacement
    • Using the Phillips #00 screwdriver, remove the single screw attached to the front casing in the top left corner. The front case should easily separate.
  7. Sanyo VPC S1275 Case Replacement: passo 7, immagine 1 di 1
    • This step is only needed for the case replacement.
    • Using the Phillips #00 screwdriver, remove the screw on the inside of the battery door.
    • Slide the battery door off of the hinge.
Conclusione
Cal Poly, Team 24-24, Regan Spring 2010 Membro di Cal Poly, Team 24-24, Regan Spring 2010
CPSU-REGAN-S10S24G24
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 1,963
