Introduzione
This is an easy to work on camera. The screws are easily accessible, none of them hidden. The case separates easily and does not require any special tools.
Remove the batteries and the memory card if so equipped. Remove the two Phillips screws on the right. Remove the four Phillips screws on the bottom.
  • Remove the batteries and the memory card if so equipped.
  • Remove the two Phillips screws on the right.
  • Remove the four Phillips screws on the bottom.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Remove the two screws on the left. With all the screws removed, the case will split easy. No tool is required. Front and back case come off at the same time. the silver midframe that houses the top buttons, remains on the camera.
  • Remove the two screws on the left.
  • With all the screws removed, the case will split easy. No tool is required.
  • Front and back case come off at the same time. the silver midframe that houses the top buttons, remains on the camera.
Aggiungi Commento
The LCD ribbon cable is folded under the holder. Do not try to remove the LCD yet. It will tear the ribbon cable. Fold the LCD way from the holder. Remove the four screws that secure the holder to the logic board. With the LCD holder out of the way, you can now open the ribbon cable connector. Use your fingernails to flip the white clasp away from the ribbon cable side. This will disconnect the cable. Remove the LCD and replace with the new one.
  • The LCD ribbon cable is folded under the holder. Do not try to remove the LCD yet. It will tear the ribbon cable.
  • Fold the LCD way from the holder. Remove the four screws that secure the holder to the logic board.
  • With the LCD holder out of the way, you can now open the ribbon cable connector. Use your fingernails to flip the white clasp away from the ribbon cable side. This will disconnect the cable. Remove the LCD and replace with the new one.
Aggiungi Commento
Conclusione
oldturkey03
Membro da: 29/09/2010
510.511 Reputazione
119 Guide realizzate
OTS Membro di OTS
Business
1 Membro
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 741
