Introduzione
The speaker is a small, round piece that is easily detachable from the device. However, to access the speaker, various prerequisite steps must be completed.
Parti
Nessuna parte richiesta.
Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone. While holding down the button, pull cover off with other hand. While holding down the button, pull cover off with other hand.
  • Place thumb on the tab located at the back of the phone and slide button towards your hand and away from phone.
  • While holding down the button, pull cover off with other hand.
Aggiungi Commento
Use fingers to grip the battery and remove it from the phone. Use fingers to grip the battery and remove it from the phone. Use fingers to grip the battery and remove it from the phone.
  • Use fingers to grip the battery and remove it from the phone.
Aggiungi Commento
Using a spudger, remove the four rubber coverings on the lower back plate.
  • Using a spudger, remove the four rubber coverings on the lower back plate.
Aggiungi Commento
Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate. Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate. Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
  • Using a Tri-wing Y0 screwdriver, remove the four 4.4mm screws securing the back plate.
Aggiungi Commento
Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate. Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate. Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
  • Remove the lower back cover to reveal part of the motherboard and the circular speaker housed in the back cover plate.
Aggiungi Commento
Gently tap the lower back casing on a hard surface to remove the speaker. Gently tap the lower back casing on a hard surface to remove the speaker.
  • Gently tap the lower back casing on a hard surface to remove the speaker.
Aggiungi Commento
Conclusione
Preston
Membro da: 11/03/2013
216 Reputazione
10 Guide realizzate
Clemson, Team 12-1, Benson Spring 2013 Membro di Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Membri
20 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 212
