Introduzione
After removing the screen protector, the actual LCD screen of the device can now be removed. This will involve disconnecting various ribbons and cables from the device.
Parti
Nessuna parte richiesta.
With the flat end of  a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath. With the flat end of  a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
Aggiungi Commento
Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver. Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
Aggiungi Commento
Carefully pry the screen protector off the phone using the flat end of the spudger. This will require a bit of force as the back of the screen protector is lined with an adhesive material.
  • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
  • Once free from the adhesive, pull the screen protector away from the phone.
Aggiungi Commento
Kit RAM Mac
Accelera il Mac. Porta la memoria al massimo.
Kit RAM Mac
Metti più memoria nel tuo Mac.
Use the spudger to pry off the front case from the left and right sides of the device. Once it has popped off, pull the casing apart with fingers. Once it has popped off, pull the casing apart with fingers.
  • Use the spudger to pry off the front case from the left and right sides of the device.
  • Once it has popped off, pull the casing apart with fingers.
Aggiungi Commento
Using a Tri-wing Y0 screwdriver, remove the 4.4mm screw. Use fingers to remove the strip from the device.
  • Using a Tri-wing Y0 screwdriver, remove the 4.4mm screw.
  • Use fingers to remove the strip from the device.
Aggiungi Commento
Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen. Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen. Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen.
  • Use a spudger to detach all of the connections to the motherboard in the back of the phone by the screen.
Aggiungi Commento
Use the flat edge of the spudger to detach the screen from the phone casing. Pull the screen up and away from the case.
  • Use the flat edge of the spudger to detach the screen from the phone casing.
  • Pull the screen up and away from the case.
Aggiungi Commento
Conclusione
Aliceann
Membro da: 11/03/2013
49 Reputazione
2 Guide realizzate
Clemson, Team 12-1, Benson Spring 2013 Membro di Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Membri
20 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 373
