Introduzione
Removing the outer front case of the phone will reveal the LCD component of the device. The case can be swapped out with another of a the same or a different color.
Parti
Nessuna parte richiesta.
With the flat end of  a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath. With the flat end of  a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
  • With the flat end of a spudger, remove the plastic covers located on the corners of the display near the hinge and above the screen, revealing four screws underneath.
Aggiungi Commento
Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver. Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
  • Remove the 4.4mm screw in each corner using the Tri-wing Y0 screwdriver.
Aggiungi Commento
Carefully pry the screen protector off the phone using the flat end of the spudger. This will require a bit of force as the back of the screen protector is lined with an adhesive material.
  • Carefully pry the screen protector off the phone using the flat end of the spudger.
    • This will require a bit of force as the back of the screen protector is lined with an adhesive material.
  • Once free from the adhesive, pull the screen protector away from the phone.
Aggiungi Commento
Use the spudger to pry off the front case from the left and right sides of the device. Once it has popped off, pull the casing apart with fingers. Once it has popped off, pull the casing apart with fingers.
  • Use the spudger to pry off the front case from the left and right sides of the device.
  • Once it has popped off, pull the casing apart with fingers.
Aggiungi Commento
Conclusione
StephenYH
Membro da: 11/03/2013
20 Reputazione
6 Guide realizzate
Clemson, Team 12-1, Benson Spring 2013 Membro di Clemson, Team 12-1, Benson Spring 2013
CLEM-BENSON-S13S12G1
4 Membri
20 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 131
