Before disassembling the device, make sure it is powered off.
  • Before disassembling the device, make sure it is powered off.
  • Remove the four 1.5mm screws on the back of the device.
Aggiungi Commento
Using a plastic opening tool, lift the metal backing from the front of the device.
  • Using a plastic opening tool, lift the metal backing from the front of the device.
Aggiungi Commento
Pull the rear panel off of the Sansa e260R.
  • Pull the rear panel off of the Sansa e260R.
Aggiungi Commento
Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
  • Grip the bottom of the battery with your thumb and forefinger and pull it away from the device.
Aggiungi Commento
Conclusione
Casey Smith
Membro da: 20/01/2012
84 Reputazione
3 Guide realizzate
Cal Poly, Team 8-15, Maness Winter 2012 Membro di Cal Poly, Team 8-15, Maness Winter 2012
CPSU-MANESS-W12S8G15
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 2
Tutti i Tempi: 2,088
