Strumenti
Nessun attrezzo richiesto.
Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
  • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
  • Lay vacuum on its back
Aggiungi Commento
Find the bottom metal plate and identify the two latches on either side of the vacuum.
  • Find the bottom metal plate and identify the two latches on either side of the vacuum.
  • Detach the two latches on either side of the vacuum by pulling outwards towards the wheels.
Aggiungi Commento
Lift off the metal plate by pulling it towards you.
  • Lift off the metal plate by pulling it towards you.
Aggiungi Commento
Identify the belt and brush roller.
  • Identify the belt and brush roller.
  • The belt is a black circle made of rubber.
  • The brush roller has bristles and is tube shaped.
Aggiungi Commento
Slide the belt off of the circular knob.
  • Slide the belt off of the circular knob.
Aggiungi Commento
Pull brush roller out and detach the belt off the brush roller. Pull brush roller out and detach the belt off the brush roller.
  • Pull brush roller out and detach the belt off the brush roller.
Aggiungi Commento
Conclusione
Caycie Pascual
Membro da: 26/09/2012
1 Reputazione
5 Guide realizzate
Cal Poly, Team 16-58, Forte Fall 2012 Membro di Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 5
Tutti i Tempi: 809
