Strumenti
Nessun attrezzo richiesto.
Be sure to unplug vacuum before disassembling to prevent electric shock.
  • Be sure to unplug vacuum before disassembling to prevent electric shock.
  • Unzip the red bag.
Aggiungi Commento
Identify the white bag liner in the red bag.
  • Identify the white bag liner in the red bag.
  • Behind the white bag liner, locate the hose connecting the white bag liner and the suction hole.
Aggiungi Commento
Roll down the spring coil to remove the white bag liner. Remove the white bag liner from the red bag by pulling upwards firmly and it will detach from the black tube.
  • Roll down the spring coil to remove the white bag liner.
  • Remove the white bag liner from the red bag by pulling upwards firmly and it will detach from the black tube.
  • Throw away white bag liner.
Aggiungi Commento
Replace white bag liner
  • Replace white bag liner
Aggiungi Commento
Conclusione
Caycie Pascual
Membro da: 26/09/2012
1 Reputazione
5 Guide realizzate
Cal Poly, Team 16-58, Forte Fall 2012 Membro di Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Membri
5 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 10
Tutti i Tempi: 553
