Introduzione
Follow this guide to replace a faulty headphone jack.
Locate and remove the screw on the bottom of the device. The screw is next to the battery compartment lid. Locate and remove the screw on the bottom of the device. The screw is next to the battery compartment lid.
  • Locate and remove the screw on the bottom of the device. The screw is next to the battery compartment lid.
Aggiungi Commento
Remove the battery compartment cover. Remove the battery.
  • Remove the battery compartment cover.
  • Remove the battery.
Aggiungi Commento
Now gently pry the two halves of the case apart.
  • Now gently pry the two halves of the case apart.
  • There are several interlocking pegs located along the edge of the device's casings.
  • Pry the pegs apart one at a time, while working your way around the case.
  • Be careful when prying apart the pegs they are made of plastic, and you don't want to break them.
Aggiungi Commento
  • The two halves of the case won't want to be separated at first. That's because the battery contact springs are in the way.
  • Push the battery contact springs down through their respective holes in the case. Now the case will come away freely.
Aggiungi Commento
  • Remove the cover to the battery compartment.
  • Remove the battery. You'll need both cover and battery out of the way for the next step.
Aggiungi Commento
The part of the casing that houses the USB jack and headphone jack is the final part which will have to be separated.
  • The part of the casing that houses the USB jack and headphone jack is the final part which will have to be separated.
  • Two clips are the only things holding this portion of the casings together.
  • Once again, gently pry the two outer casings apart by pulling them away from one another.
Aggiungi Commento
You now have access to all components found on the inside of the device!
  • You now have access to all components found on the inside of the device!
Aggiungi Commento
Locate the headphone jack on the motherboard.
  • Locate the headphone jack on the motherboard.
Aggiungi Commento
Use soldering iron to melt the solder connecting the faulty headphone jack to the motherboard. Use soldering iron to melt the solder connecting the faulty headphone jack to the motherboard. Use soldering iron to melt the solder connecting the faulty headphone jack to the motherboard.
  • Use soldering iron to melt the solder connecting the faulty headphone jack to the motherboard.
Aggiungi Commento
The solder and soldering iron will be very hot at this time. Do not touch unless wearing protective gloves as you will be burnt.
  • The solder and soldering iron will be very hot at this time. Do not touch unless wearing protective gloves as you will be burnt.
  • Be sure to always elevate the hot end of the soldering iron on a metal stand to prevent incidental burns.
Aggiungi Commento
With solder melted simultaneously remove the faulty headphone jack from the motherboard.
  • With solder melted simultaneously remove the faulty headphone jack from the motherboard.
Aggiungi Commento
Replace the faulty headphone jack with one which is in working order.
  • Replace the faulty headphone jack with one which is in working order.
Aggiungi Commento
With the new headphone jack in place, use the soldering iron and solder to create a stable connection between the motherboard and headphone jack. Be sure to allow the new solder to cool and harden. Be sure to allow the new solder to cool and harden.
  • With the new headphone jack in place, use the soldering iron and solder to create a stable connection between the motherboard and headphone jack.
  • Be sure to allow the new solder to cool and harden.
Aggiungi Commento
Conclusione
James Thorne
Membro da: 05/11/2013
625 Reputazione
6 Guide realizzate
UMass Dartmouth, Team 1-8, Shastany Fall 2013 Membro di UMass Dartmouth, Team 1-8, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G8
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 9
Tutti i Tempi: 715
