Parti
Nessuna parte richiesta.
Slide the back cover forward toward the top of the device with your thumb.
  • Slide the back cover forward toward the top of the device with your thumb.
Aggiungi Commento
The back cover is now separated from the device.
  • The back cover is now separated from the device.
Aggiungi Commento
Apply a fingernail or a plastic opening tool to the base of the battery.
  • Apply a fingernail or a plastic opening tool to the base of the battery.
Aggiungi Commento
Lift up gently.  The battery should come up and out.
  • Lift up gently. The battery should come up and out.
Aggiungi Commento
The battery is now removed from the device.
  • The battery is now removed from the device.
Aggiungi Commento
Remove the two black .265" screws at the base of the device.
  • Remove the two black .265" screws at the base of the device.
Aggiungi Commento
Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
Aggiungi Commento
Slide the rear case cover toward the top of the device with your thumb to release it.
  • Slide the rear case cover toward the top of the device with your thumb to release it.
Aggiungi Commento
The rear case cover can now be separated from the device.
  • The rear case cover can now be separated from the device.
Aggiungi Commento
Conclusione
Nicolas Coffey
Membro da: 27/01/2012
43 Reputazione
4 Guide realizzate
Cal Poly, Team 3-30, Amido Winter 2012 Membro di Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
3 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 713
