Parti
Nessuna parte richiesta.
Slide the back cover forward toward the top of the device with your thumb.
  • Slide the back cover forward toward the top of the device with your thumb.
Aggiungi Commento
The back cover is now separated from the device.
  • The back cover is now separated from the device.
Aggiungi Commento
Apply a fingernail or a plastic opening tool to the base of the battery.
  • Apply a fingernail or a plastic opening tool to the base of the battery.
Aggiungi Commento
Lift up gently.  The battery should come up and out.
  • Lift up gently. The battery should come up and out.
Aggiungi Commento
The battery is now removed from the device.
  • The battery is now removed from the device.
Aggiungi Commento
Remove the two black .265" screws at the base of the device.
  • Remove the two black .265" screws at the base of the device.
Aggiungi Commento
Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
  • Using a plastic opening tool, pry up the two arms of the case cover near the middle of the device to free them from the sides.
Aggiungi Commento
Slide the rear case cover toward the top of the device with your thumb to release it.
  • Slide the rear case cover toward the top of the device with your thumb to release it.
Aggiungi Commento
The rear case cover can now be separated from the device.
  • The rear case cover can now be separated from the device.
Aggiungi Commento
Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
  • Remove the single 0.327" silver screw on the back of the device that was exposed when you removed the rear case cover.
Aggiungi Commento
Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
  • Flip the device over and work a plastic opening tool around the base of the front case cover until it loosens.
  • CAUTION: Do not fully remove the case cover until the next step has been completed or you may damage the ribbon cable. To be safe, only lift the cover high enough to fit a spudger in the gap.
Aggiungi Commento
Open the case cover starting on the side most distance from the buttons.
  • Open the case cover starting on the side most distance from the buttons.
Aggiungi Commento
Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
  • Using a plastic opening tool, gently pry up on the top of where the ribbon cable attaches to the motherboard to release the cable.
Aggiungi Commento
You can now safely remove the front case cover from the device.
  • You can now safely remove the front case cover from the device.
Aggiungi Commento
CAUTION: Do not scrape the spludger along the top of the motherboard or you may damage the circuitry.
  • CAUTION: Do not scrape the spludger along the top of the motherboard or you may damage the circuitry.
  • Using a spudger, carefully pry the motherboard out of the case.
Aggiungi Commento
Flip the device over. In one corner, there is a large black component extending past the side of the device. This is the headphone jack. Using a soldering iron, desolder the four points at which the headphone jack connects to the motherboard.
  • Flip the device over. In one corner, there is a large black component extending past the side of the device. This is the headphone jack.
  • Using a soldering iron, desolder the four points at which the headphone jack connects to the motherboard.
Aggiungi Commento
Rotate the device
  • Rotate the device
Aggiungi Commento
Resolder the new headphone jack to the motherboard, being careful that it is fully attached and in place. Dimensions for headphone jack: 0.230" by 0.541"  1/8" diameter
  • Resolder the new headphone jack to the motherboard, being careful that it is fully attached and in place.
  • Dimensions for headphone jack: 0.230" by 0.541" 1/8" diameter
  • The red box displays the newly installed headphone jack.
Aggiungi Commento
Conclusione
Ryan Burke
Membro da: 23/01/2012
51 Reputazione
2 Guide realizzate
Cal Poly, Team 3-30, Amido Winter 2012 Membro di Cal Poly, Team 3-30, Amido Winter 2012
CPSU-AMIDO-W12S3G30
3 Membri
6 Guide realizzate
Sometimes the problem isn't that you need to solder a new jack on but that the jack has become detached from the board or worse the board has started to flake apart (the pad has detached from the board).
So get out your volt meter before you remove the old jack and test to make sure it's the jack that is the problem. My experience is that it is rarely the jack (I've fixed several of these).
There are a couple places on the board where you can solder wires onto if the pads become detached. Just be sure to glue the jack down since the pads aren't anchoring it now (so you don't put added strain on the remaining pads).
Strife Onizuka - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 12
Tutti i Tempi: 2,381
