Cosa ti serve
Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
Once the back cover has been removed the battery will be visible.
Pry the battery from the device.
Once the battery has been removed you can see the motherboard.
Unscrew 4 screws on the metal docket using a Phillips head screw driver.
The USB connector can now be taken off of the device.
Using the philips screwdriver, remove the two screws on the mother board.
Once the front cover is separated from the device, locate the four screws in the metal plate.
Using the small phillips screw driver, remove the four screws.
Remove the metal cover.
