Salta al contenuto principale
Samsung Sway Rear Cover Replacement
Cosa ti serve
  1. Samsung Sway Rear Cover Replacement, Rear cover: passo 1, immagine 1 di 1
    • Turn over the phone and make sure the slider is closed.
  2. Samsung Sway Rear Cover Replacement: passo 2, immagine 1 di 2 Samsung Sway Rear Cover Replacement: passo 2, immagine 2 di 2
    • Using your thumb(s) slide the battery cover up to remove it.
  3. Samsung Sway Rear Cover Replacement: passo 3, immagine 1 di 2 Samsung Sway Rear Cover Replacement: passo 3, immagine 2 di 2
    • Using your finger, grasp the corner on either side of the battery and pull up.
  4. Samsung Sway Rear Cover Replacement: passo 4, immagine 1 di 1
    • Unscrew the four corner .4cm Phillips head screws and the two middle .3 cm Phillips head screws.
  5. Samsung Sway Rear Cover Replacement: passo 5, immagine 1 di 1
    • Gently insert a pair of tweezers under the Samsung logo on the bottom of the phone. Then unscrew the two .4 cm Phillips head screws underneath.
  6. Samsung Sway Rear Cover Replacement: passo 6, immagine 1 di 1
    • Gently insert the plastic opening tool into the seam where the battery was located. Work the opening tool around until the back cover comes off. Make sure to be careful of the side buttons that pop off.
Conclusione
Chris Rush
Membro da: 06/27/13
306 Reputazione
3 Guide realizzate
WRI115, Team 1-2, Ruszkiewicz Spring 2013 Membro di WRI115, Team 1-2, Ruszkiewicz Spring 2013
WRI115-RUSZKIEWICZ-S13S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 260
