Introduzione
This guide will show you how to remove and replace the cable that connects the bottom and top halves of the phone.
Using your fingers, pry along the groove at the top of the phone.
  • Using your fingers, pry along the groove at the top of the phone.
  • Pull back on the rear casing until it comes free from the device.
    • The casing will make a cracking sound as it is removed.
Aggiungi Commento
With your fingers, pry from the bottom of the battery to loosen it.
  • With your fingers, pry from the bottom of the battery to loosen it.
  • Lift away to remove the battery from the phone.
Aggiungi Commento
Locate the red and white sim card located above the battery housing.
  • Locate the red and white sim card located above the battery housing.
  • Remove the sim card by sliding it downwards from its slot with your fingers.
Aggiungi Commento
Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
  • Remove the seven silver 3mm screws securing the rear panel using the Phillips #000 screwdriver.
    • Once loosened, some screws may get stuck in the casing. Use tweezers to remove them.
Aggiungi Commento
Pry around the rear panel with a plastic opening tool to loosen it.
  • Pry around the rear panel with a plastic opening tool to loosen it.
    • Prying too deeply may damage delicate components inside the phone.
  • Remove the rear panel from the phone with your fingers.
Aggiungi Commento
Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
  • Remove the four black 3mm screws securing the motherboard with the Phillips #000 screwdriver.
Aggiungi Commento
Locate the flex cable attachment at the tab with a green arrow printed on top. Pry from the side the arrow is pointing with your fingers.
  • Locate the flex cable attachment at the tab with a green arrow printed on top.
  • Pry from the side the arrow is pointing with your fingers.
    • The cable will audibly snap as it is removed from its attachment.
    • Let the cable hang loosely to the side of the phone.
Aggiungi Commento
Pull the motherboard up from the side opposite the loose flex cable.
  • Pull the motherboard up from the side opposite the loose flex cable.
    • If necessary, use a plastic opening tool to separate the motherboard from the key pad underneath.
  • Lift to remove the motherboard from the device.
Aggiungi Commento
Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
  • Insert a plastic opening tool into any side of the phone case to separate the keyboard from the rear panel.
  • Pry the keyboard away from the casing with the plastic opening tool.
  • The keyboard should come off with almost no force at all.
Aggiungi Commento
Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
  • Remove the 7 silver 2mm screws attaching the silver metal plate to the rear panel with the Phillips #000 Screwdriver.
Aggiungi Commento
Use the plastic opening tool to carefully loosen the golden metal plate.
  • Use the plastic opening tool to carefully loosen the golden metal plate.
  • The golden metal plate is stuck to the rear panel with a strong adhesive, so a moderate amount of force may be needed.
Aggiungi Commento
Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
  • Lift the gold plate with your fingers, repositioning it to slide through the keyboard casing underneath.
  • Carefully take off the keyboard casing with your fingers.
    • The golden metal plate should fit through the wide slot of the casing.
Aggiungi Commento
Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
  • Slide the silver metal plate down and away from the to the flex cable and gold metal plate.
    • The metal plate is attached to springs that offer a small amount of resistance, so it will snap into place.
Aggiungi Commento
Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
  • Unscrew the 4 black 3mm screws from the rear panel with the Phillips #000 Screwdriver.
Aggiungi Commento
Insert the plastic opening tool into the groove at the top of the rear panel. Firmly slide the plastic opening tool all around the rear panel.  The panel will audibly snap as it comes apart.
  • Insert the plastic opening tool into the groove at the top of the rear panel.
  • Firmly slide the plastic opening tool all around the rear panel. The panel will audibly snap as it comes apart.
  • These 2 pieces are attached well, so a significant amount of force is needed to separate them.
Aggiungi Commento
Lift the flex cable and position it so the part containing the metal plate can come free.
  • Lift the flex cable and position it so the part containing the metal plate can come free.
  • Pull the part containing the metal plate away from the rest of the rear panel.
Aggiungi Commento
Use tweezers to loosen the front-facing camera from the plastic casing. Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
  • Use tweezers to loosen the front-facing camera from the plastic casing.
  • Pull the black rectangular piece, attached to the front facing camera, away from the rear panel.
Aggiungi Commento
Carefully peel the blue tape from the bottom of the flex cable and set it aside.
  • Carefully peel the blue tape from the bottom of the flex cable and set it aside.
Aggiungi Commento
Use one of the plastic opening tools to loosen the flex cable from its central housing. Pull lightly on the flex cable to free it from the housing.
  • Use one of the plastic opening tools to loosen the flex cable from its central housing.
  • Pull lightly on the flex cable to free it from the housing.
    • The cable may audibly snap as it is freed from its attachment.
Picture shows a small black snap cover. This comes straight up. I then tried to pry up the cable. That doesn't happen. It slides out to the left in the picture.
huckleberry41 - Replica
Use tweezers to loosen the flex cable and speaker from the bottom of the phone.
  • Use tweezers to loosen the flex cable and speaker from the bottom of the phone.
  • Pull upward with the tweezers and the flex cable will come loose.
  • The flex cable will come free with the front-facing camera attached. In order to remove the front-facing camera, see our guide here.
Aggiungi Commento
Conclusione
Altre 2 persone hanno completato questa guida.
Jonathan Oyan
Membro da: 18/10/2013
582 Reputazione
1 Guida realizzata
Cal Poly, Team 11-32, Amido Fall 2013 Membro di Cal Poly, Team 11-32, Amido Fall 2013
CPSU-AMIDO-F13S11G32
4 Membri
6 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 1,068
