Introduzione
Samsung S5230 Star.
How to dis-assembly and change the Touch Screen. Full video you ca see here:
Panoramica Video
Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws. Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws. Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws.
  • Remove the battery, the SIM card and the memory card. Then you must unscrew 6 phillips screws.
Aggiungi Commento
After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board. After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board. After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board.
  • After removing the back housing you must disconnect the antenna cable, the LCD connector and unstuck Vol(+,-) keys. There is another one screw. Now you can remove the main-board.
Aggiungi Commento
Unstuck camera keys and remove the middle bezel. Unstuck camera keys and remove the middle bezel. Unstuck camera keys and remove the middle bezel.
  • Unstuck camera keys and remove the middle bezel.
Aggiungi Commento
Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down. Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down.
  • Disconnect the flex-cable from touch screen and the flex-cable from the small keyboard down.
Aggiungi Commento
On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation. On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation. On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation.
  • On the corners of the LCD screen there are small metal plates. Use them while you removing the screen. For best results, you can reheat with hairdryer. Be careful with this operation.
Aggiungi Commento
Now is easy to remove the touch screen. Now is easy to remove the touch screen.
  • Now is easy to remove the touch screen.
Aggiungi Commento
Install new touch screen and assembly the phone. . Did you do it successful?
Aggiungi Commento
Conclusione
Altre 9 persone hanno completato questa guida.
ZFix
Membro da: 09/12/2013
150.367 Reputazione
424 Guide realizzate
Master Techs Membro di Master Techs
Community
274 Membri
713 Guide realizzate
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 4
Ultimi 30 Giorni: 20
Tutti i Tempi: 2,658
